Sony CDP question
Ive got a Sony cdp cd player & the back where ya plug rca cables to it has 2 hookups. Which one should i use & was wondering what the 2 ment & would one of them be better than the other ? I do not have manual & figured someone here might be able to explain. TIA
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
  • boston1450
    boston1450 Posts: 7,758
    Randy-Maine
    by David WMG
  • boston1450
    Also. There is a tool that you can adjust with it ? Is there any service i can do to help make it last a few more years
    Randy-Maine
    by David WMG
  • boston1450
    Randy-Maine
    by David WMG
  • daddyjt
    daddyjt Posts: 3,171
    edited September 2015
    The "fixed" level is basically "line" level, and is pretty standard at about .3v rms. The variable is just that - there is a volume control in your cd player that will adjust this output level - usually anywhere from 0 ~ about 2.5v rms.... The variable would allow you to adjust your output level, either to perform a unique level matching to another component, or to bypass the need for a pre-amp.
    ― Aleksandr Solzhenitsyn
  • daddyjt
    boston1450 wrote: »
    Not really sure what the tool is for? Usually, the volume adjustment is with the remote. As for servicing, new belts are not a bad idea. The electrolytic caps have a 25 year life, before they start to deteriorate...
  • boston1450
    Thank you for info. Im going to run it direct to Denon POA amp bypassing the preamp, which is also hooked to the POA. So i will use Variable
    Randy-Maine
    by David WMG
  • DaveHo
    DaveHo Posts: 3,583
    That "tool" is actually the locking key for the transport. There will be a slot on the bottom, insert & give it a quarter turn. It's used to keep the transport from shifting around while being shipped. Leave it out while in use, otherwise the drawer will not open & the tray will not spin.
    I ran my Sony straight to an amp for many years. That's what the variable out is for.
  • steveinaz
    steveinaz Posts: 19,546
    ^Exactly.
    F1nut Posts: 52,101
    Many report the sound quality is not as good using the variable out on a CDP.
  • boston1450
    It will only be used as background music being its a multi disc player-so i dont have to mess with single disc when doing projects. I will use the 2910sacd for critical listening. Thanks for the info
    Randy-Maine
    by David WMG
    You have a pre-amp, so FIXED! If not, then variable is passable directly to amp, but that is not preferred!
  • boston1450
    I was thinking of using it direct so i have remote for volume. The POA has both L&R hookups for 1-normal preamp & 1-cd direct each side. If i hook it to cd direct i can be lazy with remote while doing projects
    Randy-Maine
    by David WMG
  • boston1450
    cnh wrote: »
    i did this when i first joined the forum & had great results-for what it was. I didnt notice too much difference with these old ears. I actually thought it sounded pretty darn good. I dont recall if the Sony cd player i had back then had the 2 outputs like this one has. That was the question i had. When i do try it on this player i will turn down the power on the amplifier first before hooking it up
    Randy-Maine
    by David WMG
    mhardy6647 Posts: 35,342
    The analog line-level output of most CD and multiformat players, IME, is quite "hot" relative to the traditional line level standard. Depending on the drive requirements of any given power amp, there's usually plenty of signal (gain) available from a "mainlined" disc player to drive a power amp directly (with an attenuator, of course!) and no active preamp.
    It will depend on the drive requirements of the power amp. As Gary Kaufman says, preamps need [to supply] drive, not gain" in most real-world applications. :- )
  • boston1450
    Hooked it up direct & sounds great, cdp to amp to speakers. Then shut it off & later tested the sacd to preamp to amp & all is working great. Now i can pop the amp on & 5 disc on & use the remote volume to make it easier. The Sony cdp player has the wood side panels that match with the wood side panels on the preamp & amp :) i may design some wood side panels for the 2910 so all units matchkwyqpa7n3qw9.jpg
    Randy-Maine
    by David WMG
  • DaveHo
    DaveHo Posts: 3,583
    That's a nice looking stack. I always thought running my Sony CDP output straight to an amp sounded great.
  • deronb1
    deronb1 Posts: 5,021
    I had a Sony with variable out. The maxed out variable was as loud as the standard fixed output.
  • boston1450
    It sounds great. Like i stated above when i joined the forum i tried it with a smaller Sony with great results. Im not much into the 5 disc or more players & where i can load it up & also have a Remote for volume it sure makes it sweet when working on projects & get a phone call & to have volume control on old separates is a bonus. I also still have the sacd player hooked to the preamp.. As far as does it sound better than running through preamp-havent compared because it doesnt matter
    Randy-Maine
    by David WMG
