(WTB) Car Audio Amp - 2 Channel
ambiophonics
I bought a new car the other day and the original 8 speaker stereo system needs some work. It's kind of a fun system so I thought I'd get it going again. It consists of a factory CD/Tape plus 6 disc trunk CD changer and two external factory amps - the one under the driver seat is dead and not repairable.
Anybody have a small 2 channel amp they'd like to unload? It would be used to power a pair of cheap 8" 8ohom door speakers that are the lows in a 3-way door speaker system. They are only rated at 50 watts max so it won't take much to get them going, and I'd like to fit the amp under the driver's seat again.
2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
It's strange, the car audio market in this area has really dried up, even used it's tough to find much. I checked the local pawn shop over lunch thinking that was a sure thing for used car stereo amps and they don't deal in any car stereo gear anymore! Crazy.2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
Found one locally!2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
it is rated at (on a label on the bottom of the unit)
100 x 2 Watts RMS into 4 ohms 1% TN+N
so "guessing" that is 50 x 2 into 8 ohms
but it is not published. -
oooops...my bad... just saw that you found one locally.
