Bought POLK RTi6 today for Back Surrounds!
I finally bought a pair of POLK RTi6 today for the Back Surrounds. I'm impressed by rear center sound. The Gladiator in DTS ES 6.1 was the best so far. I love them.
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
NAD C272 (2-ch Amp)
where did you pick them up from? Futureshop? How much were/are they going for??
I know what you mean, Sean. I've been eyeballing a pair of RTi12's for my computer rig.
Yes, I bought them from Futureshop and they go for $549.99 CDN. Since I work for Best Buy I got employee discount so got them for only $273.99 CDN.
NAD C272 (2-ch Amp)
Malata DVP-580 (Multi-region DVD player) -
thats a sweet deal.
Ham,
Are you looking for a new best friend???;)
Back to topic. Currently, I am using the 6's as my mains until the LSi C, 9's and 15's get delivered. I only have the 6's and the SVS 16-46 hooked up and I am totally blow away by this set up. I am hearing new detail in music I thought I knew by heart! My forensic anaylasis? These are some kick **** speakers!
ADCOM GTP-830 (pre-amp)
FREE THE WEST MEMPHIS THREE! -
Incidently, I am planning to put the RTi6's to rear channel duty I will play around with the configuration, but, it only seems fitting to let the LSxx's take "front" and "center"...pun intended.:pADCOM GTP-830 (pre-amp)
Orginally I wanted RT38i but they are discontinued with Futureshop so I went with RTi6 which are infact latest speakers. I'm glad I did, they are simply stunning. Finally I have a full blown 7.1 system now. My Yamaha RX-V1400 has DOLBY EX format which I'm using with all 5.1 and 5.1 EX coded movies. It also has a DOLBY PLIIx format which I use with all mono, 2-channel and DOLBY SURROUND movies.
I also bi-wired my POLK RTi6 to take the full advantage like all my other speakers.
I also bought 4 rolls of 50ft./30m Monster THX 16 gauge wire and Recoton and Acoustic Research gold-plated banana plugs.
I recommend POLK RTi6 to anyone.Panasonic TH-50PX80U Plasma HDTV
NAD C272 (2-ch Amp)
Me too. But remember these are bookshelves. Polks floorstanders will definitely out muscle the RTi6.
