DIY sub
Does anyone have any good websites for DIY sub instructions? My future father-in-law makes furniture as a hobby so I think this is a good potential summer/bonding project. Also do you need some type of crossover or will the receiver take care of that? I want to use my audiosource amp 3 to run the sub. Thanks for any help!
Receiver = Denon AVR-3803
DVD = Denon DV-2900
Fronts = SDA SRS 2.3TL's
(Carver m1.5t)
Center = CSi40
Side surrounds = Fxi30's
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Pioneer SX-1050 receiver
Rti38's
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's
Just type in DIY speaker or DIY sub on Google, you will get a lot of sites. The best place to start is the DIY forum at www.partsexpress.com
Bonding? You will probably want to wring eachothers necks by the time you are through!
If you use the sub preout (LFEout) on the receiver you can use the Audiosource. Try searching www.hometheaterforum.com www.diysubwoofers.org www.diyaudio.com www.hometheatertalk.com www.adireaudio.com www.stryke.com
One of my favourites is Patrick Sun's website www.io.com/~patman/Graham -
I was hoping to buy a case of beer, all the supplies and plans, and sit back and watch him build it! Thanks for the web sites, I have to check them out.Receiver = Denon AVR-3803
DVD = Denon DV-2900
(Carver m1.5t)
Center = CSi40
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Rti38's
