Receiver for RTI A5's
Howdy,
I am an audio noob. I am going about building my very first system.
I stumbled upon an awesome deal for RTI A5's so i have a pair now. I have read a lot that it should be supplemented with a sub, which i will acquire later.
I most likely will remain in 2.1 or 3.1 system.
I will use it for 60% music and 40% Movies. 99% of my content comes from streaming, which i plan to do over a Apple TV or Roku.
I am looking for a Low-End receiver, that would adequately power the 2.1/3.1 system.
I really liked the Yamaha RX-v379, would do you guys think about it? Or do you have better suggestions?
Thanks for the help!
    Do you want "good" sound or "adequate" sound ? If adequate is your goal, then that Yamaha should serve it's purpose.
    The lower end Yamaha's though have a more bright sound to them. If you want better sound, since you'll be 60% music, you have to move off the entry level receiver thinking. The Yamaha Advantage series is a big step up for musical sound in a receiver over their entry level models.
    The pioneer SC versions, HK, also have good sound for receivers. You'll need a decent sub too with those. Something from SVS or HSU, Polks micro pro subs would work also.
    Get yourself some decent cables too if you don't already. Kimber 4 series should suffice, lots of other choices. Buy used and save a ton of dough.
  • Willow
    Willow Posts: 11,272
    Too bad you're not near me I trying to sell a HK335 for cheap. But as Tony pointed out, you're better off buying a bit better and more than you currently need to future proof yourself and to avoid the what ifs.
  • deronb1
    deronb1 Posts: 5,021
    A4L. Good prices and they stand behind their gear.
  • rpf65
    rpf65 Posts: 2,127
    http://www.accessories4less.com/make-a-store/item/onktxnr737/onkyo-tx-nr737-7.2-ch-dolby-atmos-network-a/v-receiver-hdmi-2.0-wi-fi/bluetooth/1.html
    I would suggest this one. RTI A5s, CSI A4 ( or 6), and still have enough power for surrounds in the future, should you go that route.
  • Thank you for all the great advice. I am a little surprised how unanimous it is.
    I will listen to you guys and increase my budget a little. I looked around a little i could get the Yamaha RX-A740, Pioneer SC-2024-K or the Onk TX-NR646 for about the same price.
    I know its is not the top notch stuff still, but my budget is limited for now. Which one of the three would you recommend?
  • rpf65
    rpf65 Posts: 2,127
    All would work pretty well with the A5's. I'd probably go with Yamaha of the 3
  • sahilsachdeva
    sahilsachdeva Posts: 3
    edited September 2015
    rpf65 wrote: »
    Hey rpf65, Thanks! I like the yamaha more too. Can you elaborate your reasons?
    Also, i looked further, Your original recommendation Onkyo TX-NR737 is also in the same price range. What would be your recommendation now?
    Post edited by sahilsachdeva on
  • rpf65
    rpf65 Posts: 2,127
    Both are good mid-level AVRs. The biggest advantage to the Onkyo is that it is HDCP 2.2 capable, the Yammy isn't. May be something you should consider, to me, not a deal breaker.
    The Yammy has a good, and proven calibration program(YPAO). These guys pioneered height speakers. The Onk uses AccuEQ. In house design, and it's first generation. Not very much info available on this room correction algorithm. I'll give that advantage to Yamaha.
    Tough call between those 2. Not to worried about 4k, or UHD for the more correct term, right now. In a few years could be good to have. Probably lean Yamaha for YPAO.
