Time for Amp- What one?
Ok so I am thinking some amp love might help my Monitor 70s. I have pre-outs on my Pioneer AVR. I really don't want to spend an arm and a leg but would like something decent. What should I look for? Any recommendations?
  • MrBuhl
    MrBuhl Posts: 2,419
    B&K is generally available on the used market on the cheap and is pretty well thought of here. Parasound as well if you don't go with the big guns. You don' need a ton of power for those, if you don't mind the used market, that's where I'd be looking.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • afterburnt
    afterburnt Posts: 7,892
    How much do you have to spend? My arm and leg are nearly worthless lol
    tonyb Posts: 33,065
    Jp381242 wrote: »
    Maybe a better description of the sound would help us help you if your not liking it. Which receiver are you using, cables, source, room, musical preferences, etc.
  • Jp381242
    Jp381242 Posts: 60
    I would think I need to atleast up power on the left right and center. Would like to try and be under 300? Use for Music and Movies.
  • dhart86
    dhart86 Posts: 1,594
    edited August 2015
    Jp381242 wrote: »
    Hard to find a quality 3 channel amp for under $300 and that includes the used market.
    But decent used 2ch amps around your price includes the following brands
    WARM sounding: B&K and Parasound
    Also Rotel and Adcom will all make your moniter 70's sing and come in around $3 hundie used. My first quality combo was a Rotel RB 991 amp and Polk Monitor 70 speakers. Rotel also make a duplicate 3 channel amp in that model RB 993 which is very good for right,center and left channel amplification. GLW search
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • Jp381242
    Jp381242 Posts: 60
    What do you listen too now dhart?
    I tend to like a brighter sounds by the way.
  • MrBuhl
    MrBuhl Posts: 2,419
    If you like bright, and you're patient, you might find a 3 channel Acurus around 3 bills, not common, but I see them around here every once in a while. Nicely reviewed amps.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    tonyb Posts: 33,065
    Or look at Emotiva for brighter sounds, though not my cup of tea.
