replacing mw6501's
soundfreak1
Any issues with replacing 6501 with 6503's? As opposed to waiting to find a pair of original 6501's? Have an bad 6501 in my RTA 12C'S.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Somehow I was under the impression Polk still made those, as I have two newer model from Mexico with the larger dust cover. Have you called PCS to see if any are in stock?
Current Production Drivers - Vintage Support - Polk Audio http://forum.polkaudio.com/discussion/118471/current-production-drivers-vintage-support#latest (Share from CM Browser)
Freak this was edited last year by Mark going from the specs I'd say no. But looks like they are still made -
I called polk and they mave 6503's still just wondered if it would be better to try to find the 6501?Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
The problem with mixing, is the 6501s have a higher DCR, and lower FS, and VAS compared to the 6503. If it were me, I get a salvaged 6503, use it until I found a good 6501 off fleaBayHome Theater/2 Channel:
dhsspeakerservice.com/ -
westmassguy wrote: »The problem with mixing, is the 6501s have a higher DCR, and lower FS, and VAS compared to the 6503. If it were me, I get a salvaged 6503, use it until I found a good 6501 off fleaBay
Thats a good idea. If anyone has one
....Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MW6503
http://www.ebay.com/itm/Polk-Audio-MW-6503-Speaker-Driver-6-5-Monitor-12-/131581616588?hash=item1ea2e021cc
http://www.ebay.com/itm/Polk-Audio-Woofer-Driver-Speaker-SDA-CRS-MW-6503-TESTED-/231642878367?hash=item35eefdd19f
http://www.ebay.com/itm/Polk-Audio-MW-6503-Speaker-Driver-6-5-Monitor-12-/141748224454?hash=item2100da41c6afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
You can do a search on fleaBay for a 6501, and then "Follow" it. When a 6501 is listed, they'll email you.Home Theater/2 Channel:
Didn't know that thanks westmassguyMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Truth be known I'd rather get it from a polkie. I can get the 6503 local ( know someone that has scavenged some. Then be patient and pray the audio gods smile on me! LOL.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
