Tubes and protection mode on amp
dkfreebird
Can a bad tube cause an amplifier to go into protection mode?The tubes are in a Dared preamp I'm using.
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
Oppo 103
Pangea PC
Not yet,I had just swapped out the tubes from the stock ones.I have used these tubes before just last week.The dared has had a hum in it since I got it so I thought I would try the stock ones in it.They worked fine but when I got home today I switched back to the Brimar an Sylvania tubes and it played for a minute then went in to protection mode.2 Channel
Oppo 103
Pangea PC
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
I ruled out the amp,put it in a different system and it is fine.Checked all my connections and found nothing strange.2 Channel
Oppo 103
Pangea PC
Is the Dared exhibiting a high level of output sensitivity?
It has always seemed to need to be turned up very little for listening,at about nine o'clock it can run you out of the room.Also if you tap on the base you can hear it thru the speakers.I swapped the tubes and nothing changed.I heard alot of static and the some cracking on the right speaker when the amp went into protection.2 Channel
Oppo 103
Pangea PC
No warranty,I noticed the right tube flashes at the bottom on start up.I pulled the cover and didn't see any problem area but I haven't looked at the bottom of the board.Are there any measurements I can take with a dvm to check it out?I never realized the difference tubes make in the system.This is my first tube piece.2 Channel
Oppo 103
Pangea PC
I just picked up a couple of spare amps so I will give that a shot.I didn't want to take a chance with the McCormack I have so I just got a Parasound 1000 and a 750 and will use one of them with a spare set of speakers in the garage for testing2 Channel
Oppo 103
Pangea PC
Tried it on different amp,right channel is gone.The tube lights up but no sound.Is there someone who repairs these?2 Channel
Oppo 103
Pangea PC
I just got the Dared back from someone I found on Craigslist locally.I have never heard this sound cleaner.He said he found some cracked joints around the tube sockets.The sockets were also loose so he tightened those and said he noticed the heaters were a bit noisy so he added a capacitor in it to quiet it down.
I had talked to him earlier about working on an Adcom I had but sold it before I needed the work.I think I have found me a go to guy here for repairs in the future. He seems to know how to work on all the old and new equipment and his prices are reasonable. It is good to have tubes back in the system!2 Channel
Oppo 103
Pangea PC
His name is Guy.He is an old tech from California and he is laid back and easy to work with.It was just a 3 day turn around and great communication.He does tubes and solid state.2 Channel
Oppo 103
Pangea PC
Really nice to have a local "guy" like that ! Rock-onAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Dkfreebird, are you in Calif.?
Awesome, that's closer.
Yes Dallas area. I have been to his place and he is all about audio it seems.He reminds me of my older brother who is also about audio and it makes me feel at home.2 Channel
Oppo 103
Pangea PC
