Vincent Separates
kevhed72
anyone out there own Vincent separates....I thought someone did awhile back. I was taking a hard look at Audio Advisor today on this gear......thanks
I think @voltz is your man - Darryl has some Vincent gear, he turned me on to the phono stage from them that I use.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Hey Kevin
I had the Sa-31 preamplifier and upgrade to the SA-31 MK version and Red has my SA-31 and I have the SP- 331 150 wpc Amplifier plus the PHO8 Phono amp.
They are both Hybrids and I think their excellent and see no reason to upgrade again as I'd rather find speakers that work with them then change them out
I have heard some Monitor 10's & CRS+'s & Polk 703's & my DIY speakers with them and think they all sound awesome. I like my Vincent gear with the 703's even more then the Silk Audio MC100b 60 wpc tube integrated amplifier.
@Wardsweb has the SV 237 Integrated amplifier which is cheaper then my 2 separates and is 150 wpc also and they handle 4 ohms no problems.
