What's the better product
leftwinger57
My ADC 303ax are either walnut veneered all real all walnut and are getting that tired look. No lifting or chipping just a dried out look. So what's better Tung oil, or Linseed oil or something different. I might pm Jesse the wood master on this but some more dudes should know this. Sonically nothing wrong and are keepers as I call them the poor man's AR 2As with tweeters replaced with Peerless and Alnico magnets out of a set of KLH #331s. Picture is of an old set-up and have been moved since and have no sun damage.
I'd let the experts chime in, but tung oil should work OK if they originally had an oiled finish. I used boiled linseed oil years ago on some ADS L-700's, but it turned sticky over time."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
