Benchmark DAC1 versus DAC2
  • mikeyb128
    mikeyb128 Posts: 2,885
    steveinaz wrote: »
    DAC2 summary; Lots of drive and excitement. The music has body and serious depth. Nutshell: If you liked the DAC1, you'll love the DAC2.
    I'm just over a few weeks in with my dac 2. I'm so impressed with this thing. It's so smooth, huge soundstage, very dynamic, some music goes from quiet one minute to exploding the next. Love the remote, couldn't believe I went so long without one. Love the trigger for my amps, although the trigger is very close to the iec outlet. I use an aftermarket power cable with hospital grade connector so it crowds the trigger. I actually had to trim the body of the trigger wire connector with a razor blade to get it to fit next to the iec plug.
    The only negative is my sub has a loud thump when powering down. Seems only to be the unbalanced outs that do this. The balanced out to my amps don't do this. Seems from research this is normal though. I've noticed right out of the box without messing with the xlr jumpers this thing is a lot louder than my dac1, but would have to crack it open and see what the attenuators are set at to truely be sure.
    Even my girl friend says it sounds better than the dac1/pre. This is a big deal because she doesn't notice these sorts of things.This little box packs A serious amount of features. I think the improvement over the dac 1 is huge. Also love the black over silver.
    The benchmark can also be set for USB 1.1 and 2.0. I noticed quite a jump in sound with 2.0 seems to have finer detail. Forgive me for maybe not explaining myself the best, I'm not an audiophile by any means, but this thing sound fu$&@g great to my ears. Glad I took the leap.
    2 channel:
    Theater:
  • mikeyb128
    edited November 2015
    Thanks skip. I find 2 channel listening much more rewarding. I enjoy the simplicity of it. I have a bad **** home theater I rarely use. So much going on in that system, so complicated... I can listen to music for hours. I'm good for about one movie, then boredom ensues. I've even thought of downsizing and putting the cash into my 2 channel system.
    2 channel:
    Theater:
  • steveinaz
    steveinaz Posts: 19,546
    If you go to "standby" (just press "off" once) rather than full shutdown mode, you won't get the thump. Alternatively, if you power up the DAC2 first, then your amp you'll also eliminate the thump.
