CS245i versus the CS400i? What the biggest differences? Is it worth it?
lax01
lax01 Posts: 496
edited January 2002 in Technical/Setup
I have heard from most of you that the 400i will really sound better? But why is that? I have the oppurtunity to trade in my CS245i for $200 and buy the 400 for another $200. Is this worth it? I would like to use the Blue card and get the speaker for $70 bucks, but AMEX said that I had to pay for the speaker in-full, no trade-ins. So is it worth it?
Post edited by lax01 on
  • juice21
    juice21 Posts: 1,866
    edited January 2002
    listen to it, if it sounds like it's worth $200 extra dollars to you, go for it! i definitely think it is! what it has over the 245i is larger woofers, the power port - (ARC), anti-diffraction bezel (which helps with imaging), and in my mind, it sounds a hell of alot better that the 245i, not that the 245i is bad...
  • scottvamp
    scottvamp Posts: 3,277
    edited January 2002
    The cs400i not only sounds better but can handle a hell of alot more power also. It is a must if you are building a more powerful HT. What are you running for mains???? Later:cool:
  • lax01
    lax01 Posts: 496
    edited January 2002
    I am running RT1000i's as the front.
    and
    Optimus Pro LX5 in rears. I also want f/x300i
  • juice21
    edited January 2002
    i would definitely recommend the cs400i if you are running 1000's up front!
  • scottvamp
    edited January 2002
    I second that---and---the FX500i's will have the tweeters to match your upgraded setup.
    Mine:
    RT1000's
    CS400
    fx500i's
    One Word: AWESOME
  • lax01
    lax01 Posts: 496
    edited January 2002
    I just can't fit the 500i's in my budget now. And I have to decide between surrounds or the new center. I am more swaying towards surrounds because I need something that is wall mountable. My Optimus LX5s aren't. If they were, than that would be a different story. The 500i's are just more than I need. I know that the tweeter will match but they are just too damn expensive. So will I be happy with the f/x300i's?
    Thanks again.
  • schumach
    schumach Posts: 199
    edited January 2002
    lax01,
    I have close to the same setup you have.
    RT1000p fronts
    CS400i center
    F/X 300i rears
    I was looking at the 500i's, but the wife factor was involved and I just did not have enough room on the walls. I really am glad I went with the 300i's. They are a nice size and I think they sound great. Hope this helps.
    Greg
  • lax01
    lax01 Posts: 496
    edited January 2002
    Found a great deal at an authorized dealer for the same price as www.brandnamez.com. I am going to go get them tonight. I hope they are as good as everyone tells me they are.
    Thanks for all the help!
  • juice21
    edited January 2002
    a local dealer near you, or an authorized internet dealer?
  • lax01
    lax01 Posts: 496
    edited January 2002
    An authorized dealer. Graffiti's Audio- Old Georgetown Road.
    Yippee.
  • juice21
    edited January 2002
    damn, that's a steal from an authorized dealer...
  • lax01
    lax01 Posts: 496
    edited January 2002
    My dad is being cheap and saying "no." I almost hit the ceiling. Anyone to get him to buy them?
  • housej55
    housej55 Posts: 16
    edited January 2002
    Hey guys,
    I found an outstanding deal on a CS400i at brandnamez.com for 269.00. I've got a CS245i sitting in the living room still in the box that I purchased from Circuit City last week. Will be taking it back now since I've got this beast coming next week.
    Thanks for the input all !!!
    Jeff
  • juice21
    edited January 2002
    housej55, you'll be much happier with the new purchse, enjoy!:D
    welcome to the forum...
  • lax01
    lax01 Posts: 496
    edited January 2002
    Just got f/x300i and watch Star Wars Ep. 1. Wow the f/x series is soooooo much better than old Optimus. BTW, I mounted them on to the sides of my couch about 3-4 above listening levels. Is this alright. Also I couldn't get them exactly parallel because the studs weren't parallel. Is this alright? Thanks for all the help!
  • schumach
    schumach Posts: 199
    edited January 2002
    I ran into the same issue, so I use wall anchors and the speakers are not going anywhere. This allowed me to put the speakers directly across from each other.
