MW 6502 problem
xjghost
I piked up a set of Monitor 4's for pretty cheap and when they arrived one of the drivers is frozen. It doesn't move in and out at all. Is this what happens when the magnet shifts? Or is this something else?
HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's
Yes.Political Correctness'.........defined
President of Club Polk -
Yes.
Ok so what is happening? I looked at it but the magnets don't look shifted. I guess I need to put it next to another one?
Additional projects: RTA 12c's -
Replace it. You may not be able to tell with the naked eye. If they got a little thump in a drop-even with no noticable damage. The magnet will shift just enough to do just as it did. Even if they have been glued id still take caution..
boston1450 wrote: »Replace it. You may not be able to tell with the naked eye. If they got a little thump in a drop-even with no noticable damage. The magnet will shift just enough to do just as it did. Even if they have been glued id still take caution
Yea I will replace it. Just trying to learn from this instance.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Ive got some in shipping like that. Svcks. I just replaced them. I have not attempted to repair. Play around with the damaged one & ya never know i guess..
