surround vs bookshelf
SteveaReno
SteveaReno Posts: 4
edited June 2006 in Speakers
I'd like to hear from owners of both the FXi5's and RTi6's. I'm debating between the 2 right now for my surrounds, and am leaning more to the FXi5's since I figure they would offer me the best of both worlds. I currently use bookshelf speakers for my surrounds and they sound good, but they are not Polk & not voice-matched with the rest of my speakers. I know I would be happy with the RTi6's, but would I be happier with the FXi5's? That's the question. These are going to be used purely for HT, so I'm trying to find the best in-home theater experience possible with the options available to me. I'm not looking for what I should get, where I should place it, etc. Just opinions from owners as to why they got what they did, and a description of the soundfield the speakers create.
Post edited by SteveaReno on
  • racer4551
    racer4551 Posts: 373
    edited March 2004
    Hi steveareno, welcome to the polk forum,what are you using for front main and center speakers?Also are you plannig to use as side surrounds or rear surrounds?
    *HT PRE-PRO*:Rotel rsp-1068, *AMP*:Rotel RMB 1095 *DVD PLAYER*:Denon 2200,*CD PLAYERS*,Arcam Alpha Mcd 6 disk carasel,Hughes Hdtv receiver, Hughes hdvr2,*MAINS*:Polk LSI 15'S, *CENTER*:Polk LSIC, *SIDE SURROUNDS*:Polk LSIFX,*REAR SURROUND*:Polk LSI 7'S,*SUB*:SVS PB2+*.MONITOR*:Mitsubishi ws48413 hdtv,Monsterpower hts2500X2,,Sony playstation2,Harmony sst-659 remote
  • SteveaReno
    SteveaReno Posts: 4
    edited March 2004
    Thanks for the warm greetings! I'm new here because I rediscovered Polk, somewhat by accident. I have RTi8's up front, CSi5 center, Hsu sub & Onkyo TXSR701. The speakers in question will be directly on either side of the listening position, not behind.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2004
    Are the surrounds in a corner or is the back of the seating area open?
  • SteveaReno
    SteveaReno Posts: 4
    edited March 2004
    Seating area is up against a wall for the most part. The speakers I currently use are about 2' out from the back wall. One side of the room has a wall, the other is open, so they need to be fairly close to the back wall(otherwise people would just run right into them).
  • brianwayne671
    brianwayne671 Posts: 41
    edited March 2004
    I used to have the FXi30's and went with the RTi28's instead. I also have my seating area against a wall with one wall open and found that with the dipoles I lost quite a bit with the open wall due to the fact there wasn't anything to reflect off of. I preferred the direct firing bookshelves myself. Hope this helps.
  • SteveaReno
    SteveaReno Posts: 4
    edited March 2004
    Thanks for the input. One theory I had in favor of the FX is that I can set them up like bookshelf's, meaning that the one half with the tweeter & 6 1/2" driver will be facing the listening area, just like a bookshelf. Would I get the same sound/response from them if I positioned them that way, or do you think I'm better off with just the RTi6's? Even though the FXi's may not work completely as designed in my setup, I know that eventually they will be used that way.
  • Pauly
    Pauly Posts: 4,519
    edited March 2004
    The 701 IMO is a steller amp for the price and options. I have only had it about 3 weeks but was a great upgrade and like McD's "I'm Lovin It!"
    Life without music would
  • brianwayne671
    edited March 2004
    Steve-
    I know what you're saying about having the larger driver facing the listening area. I reversed my FXi30's to accomplish this very thing. I still found that you can more accurately tweak the positioning of the direct firing bookshelves to get better sound. IMO, I would probably only purchase dipoles again in a 7.1 setup as sides.
    Brian
  • josh_parsons626
    josh_parsons626 Posts: 219
    edited June 2006
    I know that for side surrounds that dipoles are the best way to go. But what about for rear surrounds I've heard that bookshelves are the better way to go. But wouldn't dipoles be better for rear surrounds than bookshelves? I mean you got them on the sides and they're going back and forth all over the side walls, then you got them on the back wall as well and the sound goes from the side wall and just continues to the back wall and to the other side wall to back up front in one big circle, right? I mean, am I totally full of it or am I making at least a little bit of sense? You would think that's why they call it "surround" sound, right?
    Don't forget to look at My Home Theater :D
    Receiver - Onkyo TX-SR503
    Fronts - Polk Audio Monitor 40
    Center - Polk Audio CS1
    Surrounds - Paradigm Cinema ADP
    Subwoofer - Velodyne VRP-1200
  • danger boy
    danger boy Posts: 15,722
    edited June 2006
    seems to me that you're working yourself into a frenzy for no reason at all.. there just isn't enough software out there to warrant a all out 7.1 surround sound set up IMHO. Go with 5.1 and use the surround either on side walls or rear walls.
    Home theater should be fun.. not a drag. I think you're thinking about this to much myself. ;)
    PolkFest 2012, who's going>?
