sealing cabinets that may come apart.
Anyone know of any spray in glue for internal corners to add strength and seal at the same time? I will be jb welding the drivers magnets and it crossed my mind about the cabinets.I could use a tube but i am lazy : )
    pitdogg2 Posts: 27,563
    Loctite power grab works very well.
  • drumminman
    drumminman Posts: 3,396
    ^ ^ ^ This. Also has low VOC's so it won't heard sensitive electronics.
    edited July 2015
    Can you use this stuff on the outside corners? I have an old pair of speakers that are coming apart (1/16-1/8" [maybe more] at one seam-edge) and it is not possible to vice force them back without cracking, damaging the sides but I would like to SEAL that corner for air tightness since this is an acoustic suspension speaker. Don't care about the cosmetics, only making sure air is not escaping from there.
  • machone
    machone Posts: 1,573
    I don't know why not. It goes on white and drys clear. Cleans up with soap and water.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    EndersShadow Posts: 17,741
    Loctite seals well. I overdid the RS-II cabinets with it...
    VR3 Posts: 29,630
    Chewing gum Sean.... Chewing gum! :)
