Room panels - how high to hang?
Joey_V
Joey_V Posts: 8,603
edited July 2015 in 2 Channel Audio
So I have 2ftx4ft panels. I am not sure how high to hang them. The room has 8 foot tall ceilings around the dropdown/furrdown. The ceilings slope back to 9ft towards the seating area.
I started to play with lateral positioning but need to start thinking vertical positioning.
I have included a photo.
You can see:
1. Panel on floor.
2. Panel 12" up (right).
3. Panel 15" up (left).
4. You can also see max ear height (without me slouching) in blue painters tape (44").
Thoughts?
  • Joey_V
    Joey_V Posts: 8,603
    A pic of rear left of room. Gotta move some panels around. Maybe remove the corner trap...r7rn2qcdcngv.jpg
  • WLDock
    WLDock Posts: 3,073
    I think centering on the tweeter height is not a bad idea.
    http://realtraps.com/art_room-setup.htm
    SCompRacer Posts: 9,137
    edited July 2015
    I'd do some room sweeps to chart your progress. Ears only will only get you so far with proper acoustic treatment placement. Even moving speakers a bit will change things for better or worse. It's good to see your results as you go.
    Room EQ Wizard is free, there is a learning curve. I use Dayton Audio's OmniMic V2. GIK advertises they will assist you with Room EQ Wizard test results.
  • Joey_V
    Joey_V Posts: 8,603
    Sean I'm flying you over
  • Joey_V
    Joey_V Posts: 8,603
    Scomp
    Good idea bro
  • Joey_V
    Joey_V Posts: 8,603
    I think for now 16" is good. Too high and there's a huge vacuum of unattended Sheetrock just below where the woofers pulse.
