Hardwood feet for rti10?
My rti10's have always had carpet spikes and I thought at one point I had rubber feet for hardwood. Any chance somthing like that is still around for these? I haven't had much luck looking online.
  • B Run
    B Run Posts: 1,887
    Are you referring to sharp spikes or the plastic ones they come with? The plastic ones will be fine on hard wood, or you could always buy the little discs to put under them if you're worried.
  • Sinister184
    They're the plastic ones. I know they're technically fine; just remembered there being another foot option.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    I believe that series of speakers had removable rubber feet that went over the spikes. They can probably be ordered from Polk's CS department either via telephone to: 1-800-377-7655 or email to: polkcs@polkaudio.com
    Mention you're a CP member for reduced prices.
    Regards, Ken
