Next...Notifications
I have a gazillion "notifications" how do you delete them?
Best Answer
Answers
  • Joe70
    Joe70 Posts: 7
    If you want to clear the notification indicator (globe icon) you just have to click on it...
    Referenced from the following JS function:
    // Clear notifications alerts when they are accessed anywhere.
    $(document).on('click', '.js-clear-notifications', function() {
    $('.NotificationsAlert').remove();
    If you want delete the notifications themselves you while probably have to find a mod with server access because there doesn't appear to be any "client-side" way to do that. At least not in my brief code review.
    Sorry, I can't be more helpful.
  • steveinaz
    steveinaz Posts: 19,546
    Thanks fellas.
  • jdjohn
    jdjohn Posts: 3,380
    Is there a way to unsubscribe from notifications for specific threads...or is it all-or-nothing for notifications in general?
  • MrBuhl
    MrBuhl Posts: 2,419
    By clicking the star in the upper right of a thread (it has yellow fill when following, No fill or white when not following) you will stop the notifications for a particular thread.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • jdjohn
    jdjohn Posts: 3,380
    Yeah, but I think once you make a comment in a thread, you get notifications whether it's bookmarked or not.
  • jdjohn
    jdjohn Posts: 3,380
    Looks like I could tweak my notification preferences if I want to that bad.
