My recently recapped Polks
cortico
cortico Posts: 587
edited July 2015 in Vintage Speakers
Hi guys, wanted to let a thank you note for the advice and help i received to recap my speakers.
On the Monitor 5B with i used clarity ESA, Mundorf resistor and new drivers (RDO-194 and MW6020). The 5JR+ received Sonicap and mills resistor.
The results are excellent, the 5B ended up sounding smoother and warmer with bigger bass. 5jr+ has more pronounced highs and mids. The sound pretty amazing when both speaker pairs play simultaneously… I am not sure is this is safe for the receiver, any thoughts?!
    F1nut Posts: 50,734
    Playing speakers side by side results in comb filtering issues.
  • cortico
    cortico Posts: 587
    edited July 2015
    msg Posts: 10,245
    I like your setup.
    How's the Marantz working out for you?
    Comb filtering -
    Is this only side by side, or also stacked/any multiple speakers in front soundstage?
  • [Deleted User]
    [Deleted User] Posts: 10,716
    congrats on your work!
  • soundfreak1
    soundfreak1 Posts: 3,414
    4 speakers do not IMPROVE sound quality ( think back why quad failed) it interferes with imaging and detail. If you must stack vertically.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • [Deleted User]
    edited July 2015
    or use the a/b switch!
    Maybe he should flip the 5jr+ so the tweeters are together... if he stacks :p
    F1nut Posts: 50,734
    Stacked speakers result in lobing. It called 2 channel for a reason.
  • soundfreak1
    Thats the way we used to stack advents back in the day.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • smglbrth
    smglbrth Posts: 1,481
    I did that once, stacked 4.5's on my 8t's. Ya, young and dumb I was back then but hell, I thought it sounded pretty good...
  • cortico
    cortico Posts: 587
    thanks, I will keep both speakers and used it alternately with A/B selector. Can't decide which pair sounds better.
    msg wrote: »
    I like your setup.
    Comb filtering -
    This 1974 Marantz sounds amazing. It had a channel down when i got it, I replaced the relay, electrolytic caps and some other problematic components about a year and a half ago with the help of some audio karma folks.
    here is the link to the thread:
    http://www.audiokarma.org/forums/showthread.php?t=563263
    I like to see my friends and family get blown away with the sound of an old piece of gear… I guess they don't expect it to sound as is.
