KARMA: Rush "2112" LP
Nightfall
Nightfall Posts: 10,084
edited July 2015 in The Clubhouse
Full disclosure: This LP has an annoying amount of surface noise on my setup. I'm sure if it went through a wash it would sound better but I still don't have one. There aren't any deep scratches but several light scratches that you can see under direct light at the right angle. This is an original 1976 copy. I will ship it out at the end of next week. Minimum of 100 posts to enter with an "In".
This is the exact version: http://www.discogs.com/Rush-2112/release/7046607
afterburnt wrote: »
Village Idiot of Club Polk
    gudnoyez Posts: 8,161
    Unfortunately you can't wash out scratches it's a permanent thing. You should get an album frame and hang it on your wall. I have done that with a couple of mine that were scratched.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    I'm in for a chance to clean it up on my RCM!
    Nice karma.
  • Nightfall
    edited July 2015
    I do have records that look worse and don't have as much noise. I didn't mean to make the OP sound like I was saying a RCM would get the scratches out. I think it's a combo of being dirty and the light scratches, I really think that it would be much better after a clean. It's not super beat up or anything I just didn't want anyone to think it's mint ++
    Post edited by Nightfall on
    afterburnt wrote: »
  • Erik Tracy
    It's a karma offering...no one should complain!
  • voltz
    voltz Posts: 5,384
    for older ones like that I use a Enzyme cleaner 1st and let it set for a few minutes, then vac, then my normal cleaner then vac then distilled water rinse and she's done!
    works wonder sometimes, I be in but I have the Vinyl & SACD...nice Karma though.
  • ambiophonics
    ambiophonics Posts: 727
    I'm in!
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
    nooshinjohn Posts: 25,922
    I would consider trying the Elmer's glue trick on this one just to try it... report back your findings. B)
  • voltz
    voltz Posts: 5,384
    your right! its just a remaster CD & Blu-ray combo... no SACD
  • muncybob
    muncybob Posts: 3,240
    In please, 'bout time I had me some Rush in the rack. If I'm the lucky winner I'll try my homemade enzyme cleaner on it.
    Yep, my name really is Bob.
  • thsmith
    thsmith Posts: 6,082
    IN !
    Saw Rush this last week and they still sound great!
  • Erik Tracy
    Is this Karma still on?
  • Msabot1
    Msabot1 Posts: 2,098
    No amount of cleaning will help if it was a lousy pressing....
  • Erik Tracy
    Msabot1 wrote: »
    Is it a lousy pressing?
  • Msabot1
    Don't know...coding in the dead wax might tell you the lot number...I have a copy of that album from March 76 that I bought new...still sounds very good on playback...one of my three favorite Rush albums I might add...
  • Nightfall
    Sorry, it's just been a crazy week. Head chef's mom in the hospital so he hasn't been at work and I've taken his place in the mean time. I'll do a drawing right now.
    afterburnt wrote: »
  • Nightfall
    edited July 2015
    Winner is Erik Tracy! PM me your info.
    afterburnt wrote: »
  • Erik Tracy
    Sweet! :)
  • vmaxer
    vmaxer Posts: 5,120
    Erik Tracy wrote: »
    Sweet! :)
    Congratulations man.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
