Tube Integrated Question - Speaker Output Impedance Selection
msg
My curiosity finally got the better of me on a small tube integrated I'd been back and forth on for a few weeks. Just when I thought I was out... here I am again with a new experiment, the Onix Melody. but that's it. that's the end. I swear it.
I'm playing with some Monitor 5JR+ speakers for starters, and will probably try it with 703's and M10's at some point.
The amp has speaker outs for 8Ω, 4Ω, and 0Ω. Apparently the 5JR+ are 6Ω.
Which output should I use?
Any input and further explanation/recommendation greatly appreciated.
here are a couple of photos
don't rip on my temporary setup - I'm renovating. at least, that's been my excuse for ugly furniture and bare floors for the past... well, never you mind how long it's been.
For me if its 6 like my kef blade I will jump to the 4 ohm taps as its gona dip and and clip on 8's.
I have one of these Onix SP3 integrated amps they are nice. Use the 4 ohm tap.
Because I am The Pumpkinking
" but that's it. that's the end. I swear it."
^^^^^^^^Hehehehehe -
The 6ohm ratings are "nominal" which really does not tell you how it varies with different frequencies. Usually there are some areas of the frequency spectrum that will drop below the "nominal" rating impediance. How well a tube amp deals with this varies greatly. I agree the 4ohm tap on the output transformers is probably a best first choice, but trying the 8ohm should be a worthwhile comparison to try and compare. Because each speaker varies greatly on this frequency impediance change and also phase angles there is no perfect answer to this question.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
I owned one of those for awhile. It's a great looking piece!
It's gorgeous, looks like it's solid as a rock.
I like seeing all the tubes without all their covers. -
Try them on the four ohm taps for a while, then try the eight ohm taps. Stick with the ones you like better.
^^^^^^^ what he said^^^^^^JC approves....he told me so. (F-1 nut)
