What do you think about this projector?
kelley
It's located fairly close so I could pick it up. I don't know a lot about projectors, but I do know my current tv is not making me happy at the moment. What would be a fair price?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3081738985&category=48653
SDS-400, SDA-1B, SVS 20-39pc+, B&K Ref 50, Denon 2900
Post edited by kelley on
This projector has been marketed as a business presentation pj by Sharp. This doesn't make it bad as a HT pj, just that Sharp has models above this model that are known as great mid level HT pjs, namely the 9000 and 10000 models.
It has 4:3 native aspect ratio which is the same as standard TVs. SVGA resolution(800x600) which is more than enough to make dvds look good.
The specs look very similar to the Infocus X-1 that I use.
MSRP is around $2200, if you can buy for under $1000 it would probably be worth the try since that is less than 1/2 list.
I have used the Notevision PG-20 this past month for a couple days and found it to be great with video, but it is yet another model by Sharp. They make dozens of different pjs.
DennisHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
