Vibrapods for the TT
afterburnt
afterburnt Posts: 7,892
I have "raised floors" not a slab. I think I should set the TT on the Vibrapods, my floor bounces. Are there any other worthwhile points to use vibration isolation?
  • Erik Tracy
    Erik Tracy Posts: 4,673
    What TT do you have?
  • afterburnt
    A Teac TN-300. The shelf I have really resonates with the floor it is sitting on.
  • pumpkinman
    pumpkinman Posts: 10,271
    No stupid Vibrapods
    Hang it from the ceiling.
    Because I am The Pumpkinking
  • afterburnt
    pumpkinman wrote: »
    No stupid Vibrapods
    LOL, like when I go spider pig? Seriously, how did you do that?
  • pumpkinman
    afterburnt wrote: »
    pumpkinman wrote: »
    No stupid Vibrapods
    All kidding aside if foot falls are a problem you should look into a wall mounted shelf.
  • afterburnt
    Not an option. I have the shelf right in between the center channel and the right main. At least is is a few feet from the sub. I just wanted to know how the vibrapods work for others. If I have to make a "Dagwood" vibrapod sammich, that's what I will have to do lol
  • hochpt21
    hochpt21 Posts: 5,423
  • hochpt21
    edited July 2015
    Hard to see but I've got a vibrapod sandwich myself. Makes a huge difference and the more sets the better.
  • Nightfall
    Nightfall Posts: 10,083
    hochpt21 wrote: »
    What all exactly is between the TT and the counter?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • hochpt21
    edited July 2015
    Nightfall wrote: »
    hochpt21 wrote: »
    Turntable...pod...shelf...pod...shelf...pod...counter.
  • hochpt21
  • hochpt21
  • hochpt21
    And I have one set under the whole entertainment stand.
    I understand it's $100, but the difference was incrementally better with each set.
  • afterburnt
    hochpt21 wrote: »
    looks like the way I will need to go
    F1nut Posts: 51,894
    Ya'll watch what those Vibrapods come in contact with as they will leave permanent slime marks.
  • Nightfall
    edited July 2015
    @F1nut What would be a budget vibration control product that you would recommend? i.e. Doesn't leave marks on anything.
    afterburnt wrote: »
  • hochpt21
    Very good point. If you have something that you don't want marked up, use a little piece of black paper or something between it and your equipment.
  • hochpt21
    nbrowser wrote: »
    Yaknow, some turntables do have decent isolation built in. I know my Debut Carbon doesn't seem to attract vibration noises and it's fairly close to a SDA speaker...
    My problem was with footfalls. If someone would walk across the living room in front of the TT, I would most likely get a skip. After the 4 layers of vibrapods...we can walk, dance, jump with no skips.
    An alternative to vibrapods are sorbothane balls from Amazon. I found them to accomplish the same thing and they are a bit cheaper.
    Pay attention to both products as there are different densities for different weights supported.
  • steveinaz
    steveinaz Posts: 19,545
    pumpkinman wrote: »
    No stupid Vibrapods
    Are those S'mores under your turntable? LOL
