Just upgraded my crossovers
Here are the speakers in question.
  • Wardsweb
    Wardsweb Posts: 942
    These are the original crossovers I built about 10 years ago. Quick and cheap to get the speakers up and running.
  • Wardsweb
    Wardsweb Posts: 942
    edited July 2015
    Now the upgraded crossovers. A big than you to Jeff at Sonic Craft for helping me pick caps and matching them for me. They are Jupiter and Sonic caps (Gen 1 and Platinum) with Mills resistors. It isn't the cleanest install. I didn't feel like totally rebuilding the crossovers from scratch.
    F1nut Posts: 51,786
    That'll be a vast improvement. I love those Jupiter "brick" caps, wish they didn't switch to the round case.
    I have to ask, are you using the Platinum caps as bypass caps?
  • Wardsweb
    Wardsweb Posts: 942
    Here is the schematic
  • mrbiron
    mrbiron Posts: 5,721
    WW, I will tell you this in full honest. Your setups are the only ones i covet on this entire forum. Those speakers are gorgeous and I assume sound amazing. Nice job!
  • Wardsweb
    Wardsweb Posts: 942
    mrbiron wrote: »
    Thanks but serenity comes not from what you have but knowing what you can live without. Enjoy your system, it's yours and you are the only one who has to like it.
