SMX Procurve Frame and Screen
[Deleted User]
Frame is 2.37 acoustically dead, 30 degree curve, wrapped in one the blackest, non reflective material known to NASA. Screen material is acoustically transparent weaved pattern Seymour HD positioned at an angle to eliminate moire and perfect for 4K. If you have not watched a movie with speakers hidden behind the screen, you simply have not experienced what movie night is like.
Screen is 130 inches
if you want to watch a movie outside around noon thirty, go SI.
$3,500,
Halen
$3,500,
Halen
This is exactly the screen the serious HT buff needs. I dont have the room but wish Idid because its the only solution to getting the center channel in the proper spot forplacement when doing front projection. If Iwas not in an apartment then Iwould for sure take it an have always wanted one.
Halen for my future reference, is there any drop in luminescence when using a perforated screen? -
The weave pattern does allow light to pass through, however given the light output of projectors these days it is still very bright. The light output deceased much more using lens memory versus using an external lens like panamorph. Another plus with using the weaved screen is using it in a curved screen, as light is reflected in a more concentrated area.
Hope that helps.
