Stylus info needed
boston1450
boston1450 Posts: 7,758
Ive been searching for a stylus for a Adcom gfc-1e & havent had much luck trying to find one. There was one on epay (used & not sure of stylus cond) cart & stylus. I just need a stylus & dont want to spend big because the unit isnt worth the bucks imo... Are Adcom Carts any good ? Any thoughts where i can look ? Tried NeedleDoctor & a couple other sites with no luck. Not sure if its better to change it out w/cart & stylus from elsewhere ???
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
