How can I...?
glemay
Hi,
I need to figure out how I can convince my dad to let me get a 2 ch. amplifier for my boat. To be specific this is the amplifier I am looking at getting since it is cheap.
He keeps telling me it will drain my battery, will it? It is only a regular battery and the motor has an alternator.
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Second System:
Post edited by glemay on
here
its the same amp, for $10 less, and its in stock
no it will not drain your battery
not at all in any way
my truck is bareass stock as far as the electrical system goes
i have the stock alternator, the only thing i have is a pretty big battery(900cca)
my smallest amp is bigger than that one
i have 1800 watts going through my truck, that amp does 120...youll be perfectly fine...you will not have to worry about anything at all
-Cody -
thanksMain System:
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a -
glad to help
-Cody
