2 MM12s
Systems
I have 2 4ohm MM12s. I plan on running them on a jbl 1200.1 amp, which is rated at 1200 watts on 2ohms. Will this configuration work? Is there any downside to having a setup such as this, or should i use a different amp for this???
Testing
Testing
Testing
Testing
Testing
nah, that'll work just fine... the JBL BP 1200.1 isn't the cleanest amp god ever put on the earth, but it's not the worst either... it's the least expensive amp that'll give you 1000 - 1200 watts of power into a 1 or 2 ohm load and that's a good thing. i've reccomended it to others for use on two momo 12's when on a budget... so happy bassing!
make sure you run 2 gauge power wire for the 1200.1 ... it'll draw a good amount of current.The Artist formerly known as PoweredByDodge -
hey.. i just picked up a pair of mm12's for 180 each at sound domain... i'm going to run mine at 2ohm on the ma audio hk2000d... puts out 1000rms.. also using 0/1 gauge.... system should pound..at least harder than anyone else's at my school... ----the cone
I dont like MA. I have 2 12" MOMO also. I am in need of an amp ......What would be a good amp? Under or around $300
