OOOOOHHHHHH! the Yamaha RX-A2050 is out
afterburnt
afterburnt Posts: 7,892
Now someone tell me why I don't want this and should get a Marantz or something.
  • mrloren
    mrloren Posts: 2,473
    I like it... I would be happy with a 1050
  • gce
    gce Posts: 2,158
    I had an older Aventage and it was a very good AVR. Then I moved up to the Marantz 7008 and just having the Audyssey MultEQ XT32 alone made it a big improvement over the Yamaha.
    I could never get that YPAO dialed in right.
    Anaheim Hills CA,
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    I have the Aventage 1010 and it suits me just fine. I think you would be satisfied with it, or the Marantz equivalent. They both are among the finest IMO.
  • afterburnt
    Getting ahead of myself. The emo needs a new home, it should work in the bedroom it is pretty plush
  • Nightfall
    Nightfall Posts: 10,083
    I'd personally buy a used 2040 or 2030 instead and save a boat load of cash but that's just me.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • polk500
    polk500 Posts: 1,171
    Hello Afterburnt,
    I have the 2040 and after reading the specs on the 2050 I would have to agree with nightfall save some cash and go with the 2040.
    It is a stunning AVR does everything well and the user interface between the iso remote app and the AVR makes it a pleasure to use.
    As for the onboard DAC I like the sound so much I disconnected my Cambridge dacmagic.
    Cheers
    Roger
  • afterburnt
    but what about dts-x?
  • polk500
    Hello Afterburnt,
    I just done some reading on the DST-X format it sounds interesting,currently there's one movie with the DST-X format or at least that all I could find.
    I was just passing on my finding with the Yammy 2040,but if you're going chase after the newest tech.. well rock on and enjoy.
    Cheers
    Roger
  • Not sure if this is correct. I heard that dts:x movies the voice dialog can be adjusted. Is that true? Thought I saw that statement on a onkyo tx-rz800 ad. But then again their is only one movie with dts:x.
  • afterburnt
    Dunno but my Yamaha RXA1040 has dialog adjustments.
  • BlueFox
    BlueFox Posts: 15,250
    DnPortland wrote: »
    I thought I saw DTS:X last night on Ex Machina. Need to check it again tonight when i finish it.
  • Polkie2009
    Polkie2009 Posts: 3,834
    You are correct BlueFox, Ex Machina is the first movie to be released in DTS:X .
  • BlueFox
    Ohhh. Do I win a prize. :)
    I noticed that on the screen, but didn't really register that it might be something new. It seemed okay on my 5.1 HT, but need to reverify that tonight. This isn't really a movie with sound effects, as it is mostly dialogue.
