Parasound 2250v2 Hi pass filter setting
afterburnt
afterburnt Posts: 7,892
The switch on the back gives the option of off, 20Hz and 40Hz. Where should I set it. It really is a pain to get to it so I want to get down there set it and leave it. sound good on off but just wanted yallz opinionz.
  • afterburnt
    nbrowser wrote: »
    Let's see, big Monitor 70 towers, tons of power...leave it full range and if you need to put a crossover setting on them, do it through your AVR, I run my SDAs full range and no drawbacks.
    Thanks nb, if there is nothing to gain I aint getting back down on that floor that obviously hates me lol.
  • If you have the SVS PB2000 ( a killer sub!) in the loop you don't really need the M70s going full range. However, it wouldn't hurt to let'em rip for a week or two full range to see how you like it.
    Either way it's going to be a fun ride.
    HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
    BR: iPad Mini, Audio Engine A5+
    2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
    Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
    Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM
  • afterburnt
    I have the xo set in the avr at 60 for the sub so is this switch redundant?
  • afterburnt
    DSkip wrote: »
    Pretty much, unless running direct. I'd drop that 60 down to 40 now that you got the big power and see what happens.
    So drop it to 40 and then what with the switch?
    EndersShadow Posts: 17,741
    edited June 2015
    The high pass is normally used for ported subs or full range speakers so you don't send em a 1hz signal and blow them due to overexcursiin of your drivers.
    It's also sometimes called a subsonic filter.
    I'd set it to 20hz and be done.
  • afterburnt
    Really I risk blowing speakers leaving it off?
    DSkip wrote: »
    afterburnt wrote: »
    The chances of it happening are slim to none, but cutting it at 20 is not a bad thing at all. Very, VERY few speakers can actually handle a 20 hz signal and produce it with any kind of volume.
    Agreed! It's UNLIKELY but....... Since it won't hurt to put it at 20, is do it and never wonder.
  • afterburnt
    k I set it at 20
  • [Deleted User]
    [Deleted User] Posts: 10,716
    and and how do you like it? :*
    Still debating this amp...
  • afterburnt
    red I am pretty sure if you are running an xpa3 off a yammi rxa1040 with Polk monitor 70,s you will love it!
    All I can really say is that I used to prefer the sound of 7 channel prior to getting the Parasound now 2 channel is prefered. Not that the emo was that bad on 2 channel this Parasound is just better. Plus putting 200w to the 60's on the sides does sound a bit bright in comparison.
  • [Deleted User]
    Thanks afterburnt!
  • afterburnt
    Thanks afterburnt!
    Don't thank me, now I know I NEED an A31lol
  • afterburnt
    The truth is I have enough new stuff to keep me busy figuring it out that I am good for a little while at least...
    msg Posts: 10,532
    edited June 2015
    afterburnt wrote: »
    ha! famous last words! B)
    (from experience :) )
  • afterburnt
    DSkip wrote: »
    Good to hear. I think you should take a few weeks to reflect before jumping on any other products.
    D the next move would be to take advantage of a FF to get me some Lsim's. Otherwise I am good to go for a while unless you have an A31 that you are dying to get rid of lol.
