I need more plugs
  • concealer404
    concealer404 Posts: 7,440
    Why not take the opportunity to step up to an APC H10/H15?
  • afterburnt
    afterburnt Posts: 7,892
    Is there anything wrong with using two separate units for the same system?
  • afterburnt
    Is that gonna be good for 3 amps and a sub?
  • concealer404
    afterburnt wrote: »
    Can't speak from experience, but it ummm... has more plugs? Or something? :wink:
    I've been running an H10 for years, haven't really had a problem with it or been limited by it. I run everything through it, but i must say i haven't had 3 amps going at once.
    3 amps ? Normally we don't plug amps into these sort of things because they limit current. What kind of amps are we talkin' about anyway ? Most modern equipment is able to fend off most surges anyway, unless you have a real problem in your area.
  • afterburnt
    tonyb wrote: »
    My 2 emos and this new parasound that I am sitting here waiting for
    Do you experience a lot of brown outs or fluctuations in line voltage or are you just being cautious ?
  • afterburnt
    Mainly being cautious but there used to a lot of power droops here but they don't seem as bad since the power company changed out the capacitor banks on the pole. I am at the end of the line and I hear that is bad for power fluctuations. My AC unit kicking on always dims the lights too.
  • afterburnt
    Hell i don't know if I can run all of this stuff off of the same circuit
  • mikeyb128
    mikeyb128 Posts: 2,885
    My Sunfire worked just fine plugged into my Panamax. One day I decided to plug it directly into the wall. It was like I pulled blankets off my speakers. It was quite the revelation.
    2 channel:
    Theater:
  • afterburnt
    mikeyb128 wrote: »
    mikey really? What exactly are you running?
  • mikeyb128
    I use a Panamax m5400pm. It does have high current outlets, and Is not current limiting. Just sounds better plugged into the wall. I have my mono blocks plugged directly Into the wall as well. I do live in a newer house though.
    2 channel:
    Theater:
  • afterburnt
    thanks mikey, this house is cica 1930. I think the Little Rascals filmed stuff here
  • mikeyb128
    edited June 2015
    I lived in a house once that was 100 years old. Had my electrican buddy wire a dedicated 20 amp circuit with its own breaker. Never had a issue with power after that.
    2 channel:
    Theater:
    F1nut Posts: 52,022
    mikeyb128 wrote: »
    Bingo!
  • afterburnt
    Huh, do I need it all on a power strip lol? We will see!
  • afterburnt
    Everything is hooked up and working like a ****, so far struck a good balance but the fronts are outperforming on the Parasound. I guess I need more.
    More what ? Money ? lol
  • afterburnt
    mikeyb128 wrote: »
    Mikey why do you think that is? Do you think the unit I am using limits the current?
    Panamax M8-AV-PRO Home Theater Power Management
  • mikeyb128
    I'm not sure my friend. I just tried it one day and haven't looked back. I'm sure someone else with more knowledge on that subject will jump in. I felt it sucked the detail out of the amp. Lol
    2 channel:
    Theater:
  • polrbehr
    polrbehr Posts: 2,852
    afterburnt wrote: »
    What kind of A/C, size in BTU, voltage, own circuit?
  • afterburnt
    polrbehr wrote: »
    afterburnt wrote: »
    I would have to go look it is a central air unit on its own circuit
  • polrbehr
    That's fine then.
    You said the house is older, and so you might be limited in what you can do about that. Without more info it's difficult to make a reasonable suggestion to you. I was concerned that it was something like a 12K BTU window unit or something, drawing lots of startup current on the same circuit as your lights.
