How do I unfollow a post?
I don't want to turn off my notifications, but there are some posts/topics I no longer want to follow.
Best Answer
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Answer ✓
    Here's the response from Vanilla:
    "It seems "Jasper67's" notification
    preferences are set to receive emails whenever someone posts in a
    discussion he's started or a discussion in which he's participated. As
    such, there's no way to stop those emails on a per-discussion basis. What
    we've seen as the best way to handle this going forward is:
    - turn off notifications for own discussions and participated discussions
    - turn on notifications for bookmarked discussions
    - bookmark the discussions for which you'd like to receive notifications
    That way, if you tire of receiving those notifications, you can simply
    unbookmark the discussion.
    Hope that helps!"
    Cheers, Ken
Answers
  • ken brydson
    ken brydson Posts: 9,005
    Click on the little sprocket icon up to the right under your name and edit your email notifications.
  • Jasper67
    Jasper67 Posts: 33
    I checked that out but it looks like that is a global change for the forum. I just don't want to be notified about a particular post.
  • ken brydson
    Try "unhighlighting" the star next to the thread title.
  • Schurkey
    Schurkey Posts: 2,122
    If that works...
    ...THANK YOU, THANK YOU, THANK YOU. What a blessing.
    My thanks also to Jasper67, I was getting ready to ask the same question.
  • Jasper67
    Jasper67 Posts: 33
    the star is not highlighted on the post I would like to un-follow. Any other suggestions?
  • JeremyJ
    JeremyJ Posts: 17
    where are you getting the notifications?
  • Jasper67
    Jasper67 Posts: 33
    via email, sorry for the delay in responding. I don't want to turn off all my email notifications, just from specific posts.
    EndersShadow Posts: 17,705
    Jasper67 wrote: »
    Each thread at the top has a little star icon. If its filled in and yellow it means you would get a email notification for that thread.
    Click on it again (so its not filled in anymore) will remove it from your subscriptions and you wont get notified if someone posts on that thread.
  • Jasper67
    Jasper67 Posts: 33
    while in theory you are correct, but that doesn't work, at least not for me. The star is grey and I can flip it to yellow and then back to grey and I still get emails.
  • Hello,
    I'll check on that for you.
    Ken
    edited August 2015
    Check your notification preferences and see if something there might be causing it...
    While logged into the forum, copy and paste this URL in the address bar to go to where your notification preferences are
    http://forum.polkaudio.com/profile/preferences/Jasper67
    If that doesnt work click on your name -> edit profile -> notification preferences
    There is one to notify you if someone comments on a thread you posted in. Mine is turned off. Yours might not be.
    There are still come bugs in the system. I get some notifications that were not triggered by me, occasionally, and then they stop coming with no action on my part!
  • Jasper67
    Jasper67 Posts: 33
    Thanks for all the advice, I have changed my preferences and I'll let you all know what happens. In a nutshell, I posted in the SDA deals post, and now that I have my own, I don't need to know about all of these deals that people find. Same thing for the SDA playlist post, I would rather just check out what people recommend vs. getting an email every time someone posts. Make sense?
  • Schurkey
    Not really. THAT THREAD (SDA Deals) was the one that I wanted to not receive e-mails for; and just clicking the star fixed it for me.
    I wonder why that doesn't work for you.
