Which sound bar?
mcholak
mcholak Posts: 1
edited June 2015 in Speakers
I need some help, I've been researching sound bars and feel more confused now than I was when I started. I have read good things about Polk sound bars and intend to order the Atrium 4's for my outdoor setup, the problem is I can't tell the difference between the options. My room isn't huge, maybe 15 x 20. I don't need something super loud but the TV speakers suck, especially with the TV mounted to the wall. I know I want a sub and BT, but beyond that I don't know how to choose one over the other.
I don't have a receiver so I want a powered unit. My living room is tile, not sure if any of these measure the ambient noise or not or if that matters. It will be paired with a 50' LG. I don't know what else to share or what else is pertinent so if I missed anything please let me know. Thank you in advance for your help!
  • Mikey081057
    Mikey081057 Posts: 7,127
    i use a polk sb6500bt with my b/r tv and it works good. it has bt and a wireless sub.
    Garage | Polk Monitor 5B's
  • RamZet
    RamZet Posts: 792
    for my bedroom I just went with Samsung...
    B/c I got it for free.
    Unit sounds great for TV and it has BlueTooth too.
    http://www.amazon.com/Samsung-HW-F450-HW-FM45C-280-Watt-Soundbar/dp/B00HZQ6I4O
    B&W CM9Classé Sigma
  • D2Lo
    D2Lo Posts: 352
    Have you checked out the Polk MagniFi. Has Bluetooth and Voice Adjust feature where you can adjust the volume of dialog in movies and TV.
    http://www.polkaudio.com/magnifi/d/1237
