Help with receiver or pre
My current setup is a NAD pre with an Adcom 545 amp and SDA 2A's. I have been pretty happy with this setup for 10+ years now using it for both music and HT. But I was just given an SVS PB-10isd and the NAD pre does not have a sub output.
Currently looking at the Outlaw 975 but curious what you guys think. I do not think I would be adding any surround sound to my setup, but you never know. wondering if I would be better off getting a receiver with pre-outs just in case I decide to add surround sound speakers.
Any advice or recommendations?
Setup:
Adcom GFA-545 amp
Nad 1600 pre
Dual 704 TT
Pioneer 707 R2R
Pioneer DV-578A Multi-format
Polk SDA-2 Mains
    EndersShadow Posts: 17,688
    You could always just use two y cables from your left and right preouts and run it into the sun that way. Otherwise if you have speaker level inputs there is another option.
    If your happy with your setup I'm sure there is a way to add the sub without changing gear.
  • Spawndn72
    Spawndn72 Posts: 453
    I hooked the sub up to the left channel of my pre using a y-cable and while it seems to work ok, I can't help but think it would be even better hooked up to a dedicated sub-out. Plus, now that I am looking, the upgrade bug has hit once again.
    Well, after looking around I decided on a Marantz 7008.
    Time to add a few speakers :)
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Polk SDA-2 Mains
  • Spawndn72
    Got the new Marantz hooked up last night and the sub sounds much, much better.
    Setup:
    Adcom GFA-545 amp
    Nad 1600 pre
    Dual 704 TT
    Pioneer 707 R2R
    Polk SDA-2 Mains
