MM6501 Technical Specifications for individual drivers
secondhand_pie
secondhand_pie Posts: 2
edited June 2015 in Technical/Setup
Hello,
I run the MM6501's; and they're great. I'm planning a 3-way active front stage, and I'd like the MM6501's to be a part of that.
It's difficult to plan around the complete lack of any meaningful information about the speakers. I've e-mailed Tech Support 3 times; it took them 13 days to get back to me, and when they did, they sent a link for the product specs on the website. Frustrating.
A forum search has proved fruitless as well.
I'm looking for specifications (Thiele parameters, Frequency Response graphs, power handling, Impedance) on the INDIVIDUAL woofer and tweeter; as an example:
This data sheet from Dayton Audio
Where can I find this information?
Thanks in advance for any help you can provide.
Best Answer
  • dorokusai
    dorokusai Posts: 25,576
    Answer ✓
    They are not publicly available in depth.
