Outdoor (sort of) bookshelf speaks
I have a covered porch with a prewired shelf at the back that is, for the most part, out of the elements. I can't imagine this are getting wet (no evidence of it being wet either), sunlight can't reach the area either. The only exposure issues I'm concerned about it heat and dust, I guess. I will bring them in in the wintertime.
The question is... Are there decent outdoor speakers that I should use in this application, or should I just buy some bookshelf speaks that would do the job better for similar money and accept that something might happen to them from the elements? I have some RTi28's I could put out there too, just unsure of how the heat might effect them. (I"m in Milwaukee, so heat is relative I guess. )
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
  • tratliff
    tratliff Posts: 1,801
    I had the same type of setup at my last place. I used a pair of Boston bookshelf speakers for a number of years. They did not have much problem with the humidity but the dust was a problem. They got really dirty and could not really be cleaned like an outdoor speaker.
    My thought when I put them up was that they were extras and if they did not last then I really was not out anything. They worked well and performed better than most outdoor speakers.
    I sold them with the house, last I saw them they worked fine after about 6 years.
  • rooftop59
    rooftop59 Posts: 8,120
    Right now I an using some old rt15is with tri-lam dome tweets, before that I had rt35is. Yes eventually the elements will kill them, so done put new $500 speakers out there. But those small olders rtXXi speakers can be had for under a $100 shipped on ebay, so if they last a few years I think you got your money's worth. Even better if you having an extra set sitting unused...
    Game Room 5.1.4:
    Bedroom 2.1
  • Lowell_M
    Lowell_M Posts: 1,660
    Ok. Great advice. Thanks. I think I may replace the RTi28's inside, and use them as the outdoor speaks. I'm not that satisfied with them where I'm using them right now, so if they last me a few years in outside duty, I'll be happy. I was just worried I'd kill them in a matter of months putting them outside.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2015
    FWIW, I have had a pair of Energy C-3 bookies under my covered patio for over 5 yrs. They stay outside all year long. I will admit to having to clean bird **** off of them from time to time, but the drivers look fine, and the cabinets always clean up well.
    When we get moved, I'm finally going to get some Polk outdoor speakers and retire my C-3's to garage duty---they've earned it.
  • WagnerRC
    WagnerRC Posts: 2,209
    I picked up a pair on near speakers since we live on the sound. damn are these speakers built well. http://www.nearspeakers.com/lb-6.html
  • teekay0007
    teekay0007 Posts: 2,288
    We have a couple of pairs of Atrium 5s in my family. One is in MN, the other in WI and both are mounted outdoors under the eaves of a roof. They both are going strong after several years, look close to new and sound surprisingly (for their size) terrific. One pair was brought in over two of the winters while the other pair stayed where mounted from day one. No problems, great sound, great price and look like they're going to go for many more years.
    Highly recommended.
