biamping lsim 706 what type of cablewould you use for tweeter section
Just curious about what typ of cable will best suit the tweeter section..i use transparent throught out the rest of my system.
  • ptrooper
    ptrooper Posts: 501
    Hey Dskip..Thanks for your info..
    I allready have biwire from a rxz11 yamaha...sold this as i now have 3 x sunfire signiture series 2 power amps and will be running them from a JLTI modded oppo 105D used as a preamp in 5.1 ......Problem is its a stereo amp so i need to use both left and right channels.I will use the transparent plus biwire for the time beingon the low section and was wondering what other peoples opinions would be in regards to a cable just for the hi frequency section .I will probably order more transparents cables but have allready blown over 20 000 aussies on cables alone. where does it stop : )
  • ptrooper
    ptrooper Posts: 501
    i could also mono the amp but i was told 1200 watts into 8 ohms was a bit much (Vr3)
  • ptrooper
    ptrooper Posts: 501
    Cheers i wasn't sure if it was ok to do that
  • voltz
    voltz Posts: 5,384
    I have a Adcom 5503 200x3 WPC and I've used it many times with just the 2 channels.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Ran my 7 channel sunfire for years with only 5 channels :)
    2 channel:
    Theater:
