LS70
skydynamic
my uncle gave me a pair of LS70, at least i think it is. there's no marking or anything like that. well the mid range driver of one the speaker have this buzzing noise when i play Dire Straits "You and Your Friend". So im thinking it might be broken. can any of you let me know where i can get a replacement part? thanks.
Welcome to CP and congrats on the new to you speakers. I don't believe Polk stocks those drivers anymore but I could be mistaken. Worth a call to CS on Tuesday to check. In the meantime, for giggles try removing and rotating the affected driver 90 degrees and re install. Sometimes that fixes the problem. Good luck!
thanks, i'll contact them tomorrow. might have to look for an old pair and get the part from it.
skydynamic wrote: »thanks, i'll contact them tomorrow. might have to look for an old pair and get the part from it.
Did you try rotating the suspect driver?
