t/s params
neomagus00
i'm using unibox to model the subs i'm looking at, and several are dvc. which t/s parameters change when you switch from series to parallel wiring (on the sub itself, not with any other drivers)? for example, i'm pretty sure Re changes, but i dont know by how much. my choice has pretty much come down to looks and flavor, rather than performance, but its good info to have anyway. thanx.
Post edited by neomagus00 on
And, where can i find the Re value for the MM104? I'm using an approximate value of 3.85 for the moment, but i abhor guesses.It's not good, very fundamentally simply not good. - geolemon
go to www.polkaudio.com/car
click on Polk/MOMO on the sidebar
click on that sub, and it should be under the specs
if not, call polk
-Cody -
i called; the Re is 3.6 for the mm104, if anyone ever needs it.It's not good, very fundamentally simply not good. - geolemon
