Polk Audio Monitor 10 (Original) Crossover Modification
VR3
VR3 Posts: 29,627
edited May 2015 in DIY, Mods & Tweaks
Tweeter Network -
Clarity Cap ESA
Mundorf Mox Resistors
Stock Inductor
Totem Silver Internal Wiring
Midbass Network -
Clarity Cap PX
Stock Inductor
Other Features -
Aluminum faceplates (original crossover mounted inside cabinet)
Gold Plated Binding Post, Insulated
Bi-Wire with Neutrik NL4 connection available as well
Point to point wiring
    msg Posts: 10,534
    Nice. What is the Neutrik NL4 for?
    Are the jumpers also Totem Silver? Do you tin these or put them in bare?
    Just starting to consider more the mods for M10s and 2.3TLs.
    VR3 Posts: 29,627
    The NL4 was there just as an alternate speaker connection as the plate is designed for SDA speakers and the hole was there. NL4 is an great connection
    The jumpers are actually Supra Rondo which is already a tinned copper so they don't really require any type of tinning to prevent corrosion
    Thank you :)
    msg Posts: 10,534
    oh, haha, I thought you'd gotten really fancy and were now offering SDA'ing conversions now, hehe
    just had to look that up - with Supra Rondo, is each strand tin plated all the way through?
    I was meaning tinned more for neatness/longevity in the connection. you know how bare leads can get sloppy after a while with changes? presuming for this application, though, that the client would be using banana plugs, and not bare leads or spades to the terminals, so these jumpers would be undisturbed?
    VR3 Posts: 29,627
    Truth be told I usually include the jumpers as I use them for test purposes, most people use their own form of jumpers or bi-wire cables. No one has really ever requested anything special for the jumpers but I am careful to make sure no strands are hitting incase they keep them installed, the wire barely fits through the binding post hole :tongue:
    Supra Rondo is a great wire, especially for internal wiring. It has an extremely high strand count, super flexible, sounds great, I enjoy using it.
