Very interesting article re: Digital Watermarking
vc69
http://www.mattmontag.com/music/universals-audible-watermark
I really had no knowledge of this until I read the article linked above. Quite an eye-opener.
-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's
Perhaps only interesting to me...
-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
VTL 2.5
B&W 801's
Transparent IC's -
I understand why there is a need for watermarking, just don't know why they felt the need to run it directly in the vocal ranges, it could have gone anywhere in the audio band since they have to use software to detect it consistently. A pattern at 18khz beneath the audio track would have been just as effective, but would have never been heard by the majority of listeners. In fast moving music, it isn't noticeable, but in piano or female vocals, it comes across as a distortion, that can be heard more often.
I guess with most popular music being recorded within the new levels of the "loudness wars," the pattern is way below recording levels. Soft acoustic music can suffer.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
