"Y" adapter
chiuahua
chiuahua Posts: 4
edited January 2002 in Technical/Setup
HI!I m confused about Y adapter.I have to use
or not use?My sub is velodyne cht-10 and my receiver
yamaha rxv-800.the cable is AR. 4 rt-35i and cs245i.
Thanks any help.
Chiuahua - Brazil.
Post edited by chiuahua on
  • sgtgto
    sgtgto Posts: 310
    edited January 2002
    Hi:
    If your sub has two lfe inputs use a Y adapter from your receiver to the sub.
    Gary
  • scottvamp
    scottvamp Posts: 3,277
    edited January 2002
    Ya, like the thread responded to earlier. Both my sub's have a left and right lfe inputs so it just make since to use them. Just my logic I guess. :)
  • trubluluc
    trubluluc Posts: 2,067
    edited January 2002
    guys-
    Are you sure you have 2 (unfiltered) LFE imputs?
    Usually you have a filtered and a unfiltered.
    The left and rights are the rca imputs and they are filtered. So unless you have an unfiltered
    sub-out on your receiver, you are filtering the signal twice.
    -luc
  • goingganzo
    goingganzo Posts: 2,793
    edited January 2002
    your sub has a dual voice coil and the left and the right are for each of the voice coils that is y you have 2
  • scottvamp
    edited January 2002
    Thanks Goingganzo, you nailed that one. I explained that to people before. Some subs also have more than one speaker like my PSW1200. I do not really understand the whole confusion of the filtered unfiltered thing. You have a sub out on the amp and a input in on the sub. That is the basics. So if it is filtered twice I havent noticed.
