Polk RTi A3
vengat2000
in Speakers
Hi,
Which Amplifier or Receiver is suitable for Polk Rti A3 book shelf speaker to listen music with vibrated bass..
Need to match with watt/ohms of speaker spec.
Thanks & Regards,
Vengat.
Thanks & Regards,
Vengat.
I'll confess to being a grumpy old guy living in seclusion - what is vibrated bass?
As for amp or receiver - do you have a budget in mind? Is used ok?
What are your listening preferences for volume level, what other components will you be using as your music source?
Will your setup be just a pair of RTiA3s or will you be using a sub and/or surrounds as well?
You want something that will "warm" those speakers up. Parasound, B&K, etc. There are some posts/sales on this site about those you can look at.Currently orbiting Bowie's Blackstar.!
