Rotel RA-12
RamZet
in Electronics
I got my hands on the Rotel RA-12 this weekend. I think Rotel is aiming for a budget product with this unit. Its an integrated amp (2ch) with 60w/channel. You can connect up to four speakers ( A,B,A/B, or off). The amp is what you would expect from a Rotel amp.
Im using it as a Pre-amp. What I like most about this unit is the built in Wolfson WM8740 DAC chip. I connected my Sonos Connect to it and streamed some songs from Deezer Elite and I have to say I'm impressed. It can also decode your 24/192 FLAC files.
This unit will only set you back $700. If you're in the market with a low budget this has to be on your radar.
There's a matching CD player ( also with a built in Wolfson WM8740 DAC chip), DAB+ FM Tuner, and Internet radio Tuner.
Anybody else have this unit?
http://www.rotel.com/UK/products/index.htm?cat=159
B&W CM9Classé Sigma
