FS Adcom GFA 2535 3 or 4 channel power amp.
geppy1
FS Adcom GFA 2535 3 or 4 channel power amp. it is in excellent shape and works as it should Includes copy of the manual. Specs listed below. Asking $175 or BO Thanks
PM for pictures
The GFA 2535 is really two GFA-535s in one, with the flexibility to drive three or four channels.
A single switch on the GFA-2535's rear panel lets you select 4-channel operation, or bridge two of the channels for a 3-channel configuration. In the 3-channel mode, the GFA-2535 brings your home theater to life, delivering 200 watts of clean, distortion-free sound to the center channel, and 60 watts to each of the rear channels. Add it to your existing 2-channel amplifier and you'll be at the center of a superbly balanced, awesomely powered stage with sound so real you can practically touch it.
For audio applications, the GFA-2535 in the 4-channel mode acts as a pair of 60 watts-per-channel amplifiers to drive two sets of speakers. With two of the channels bridged, it delivers 60 watts each to a pair of satellites, and 200 watts to a single subwoofer for an incredible display of musical strength so real you definitely can feel it.
Three channels or four, home theater or home audio, the award-winning Adcom GFA-2535 gives you twice the versatility of ordinary amplifiers. And twice the value that has made Adcom famous.
Power Rating
·60 watts continuous average power into 8 ohms at any frequency between 20Hz and 20kHz with both channels driven at less than 0.06% THD.
·200 watts continuous average power into 8 ohms at any frequency between 20Hz and 20kHz at less than 0.09% THD, bridged, AMPLIFIER B only.
IM Distortion (CCIF, Any Combination from 4kHz to 20kHz).....60 watts into 8 ohms .....< 0.01%
Power Bandwidth (-3dB) .....7Hz to 150kHz
Dynamic Headroom into 4 ohms .....1.5dB
Signal-to-Noise Ratio, A-weighted......60 watts into 8 ohms.....< 100dB
Gain .....27dB
Input Impedance .....22,000 ohms
Input Sensitivity
60 watts into 8 ohms.....1.0V rms
1 watt into 8 ohms.....130mV rms
Input Sensitivity, Bridged, AMPLIFIER B, Only
200 watts into 8 ohms.....1.8V rms
Damping Factor .....20Hz to 20kHz > 400
GENERAL
Power ...... 110-120VAC/50-60Hz
Maximum Dimensions.....5.5"(140mm) x 17"(432mm) x 14"(356mm)
Weight .....35 lbs.(l5kg)
PM for pictures
Power Rating
Gain .....27dB
Input Sensitivity
GENERAL
BUMP
