Help please with CD player noise
I recently bought a Cambridge Azur 540C CD player (without testing it).
It has an intermittent static sound that comes and goes.
On some tracks it sounds fine, then the noise starts, kind of a rhythmic, pulsing, hissing, distortion. Sometimes gets so bad it is unlistenable. Seems worse on inner and outer tracks.
Same problem whether I use the RCA outputs or the optical output.
I get the same noise (sometimes) when I am using it as a transport to a DAC, or as a CD player.
I blew it out with compressed air, an also ran a CD/DVD cleaning disc with a brush. Can't find my tiny Torx drivers to get the case off to clean the lens.
I like the sound quality when it is working without static.
Has me mystified (which is not hard to do). After all.....I'm just a caveman.
Any suggestions on what the problem is or ideas for fixing it?
Thanks!
Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player
    F1nut Posts: 52,152
    Is the noise coming through the speakers or is the noise inside the CDP?
  • Oh, good point, the sound is coming through the speakers. The player itself does not seem to make any unusual mechanical noises.
    Thanks!
  • vc69
    vc69 Posts: 2,500
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
    F1nut Posts: 52,152
    Since you don't hear any noise in the player it could be anything from a bad solder joint to a funky logic board.
  • BlueFox
    BlueFox Posts: 15,250
    Well, if it happens as both a transport, and as a player, then that means it is in the digital circuitry. This will be a hard problem to troubleshoot since it is intermittent. You can try reseating any connections, but a component failing seems more likely. Is it heat related? That is, does it happen right away, or has to play a while before occurring? Heat related is another indication of a component failure.
