Polk Audio SDA 2BTL Mod
VR3
This is a top notch piece, Clarity ESA, Jantzen + C-Coil, Supra internal wiring, Mundorf resistors! The only thing missing from the picture is the lexan substrate for the C-Coil.
Sweet cost?Home Theater
I try not to use the forum as a sales platform, just like to post stuff in the DIY mods section. If you would like to send an email to Vr3Mods@GMail.com we can talk more about that...
Thank you- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Email sentAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Ok, as someone who has done the same exact crossover for my 4.1TL's, all I can say is that is seriously sweet dude. One question - why four binding posts per speaker?Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Thank you sir!
I converted them to a bi-wire.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
5 posts per speaker
Bi-wire and Neutrik DreadnaughtAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Is it just two posts in parallel or more to it than that?Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
You remove the "J1" and "J2" jumper and install a 5 position Molex at the input. Instant bi-wire.
And to be honest, This is the first one I have done like this and I missed the removing the J2 jumper. Will be doing that shortly... good question!
Very cool!Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Beautiful work.2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
