Fiio E17 Headphone Amp and other items.
Irrenhaus
Hi all
This is my first post on the sale forum. I have a Fiio E17 that I don't use anymore it is in great condition, about 20hr of use. The only thing missing is the rubber pads, all else is included. It will also comes with a USB OTG cable. I will take $90.00 ground shipping included to the 48.
Also have a pair of Pioneer SP-FS51-LR they are in good condition a few scratches but nothing bad. They were use as mains for a short time and then as background garage music. I will take $40.00 LOCAL SALE ONLY.
I also have a JBL L8400P 12" Subwoofer. Is in good condition a few blemished and scratches. I don't have the grill. I am first owner but the unit was a floor demo I will take $100.00 and LOCAL PICK UP ONLY don't have the box and is about 60lbs. Here are the specs:
General Specifications
Enclosure TypeSealed
FinishBlack Ash
SeriesStudio L
Audio Specifications
Frequency Response22Hz – Low-pass crossover frequency
Crossover Frequencies50Hz – 150Hz, Continuously adjustable
System Specifications
Amplifier Power (Peak)1200W
Amplifier Power (RMS)600W
Speaker Specifications
Low-Frequency Transducer12" (300mm) PolyPlasTM cone with rubber surround and cast-aluminum chassis; HeatScapeTM motor structure; Symmetrical Field GeometryTM (SFGTM); oversized fiberglass voice coil; magnetic shorting ring.
Well for local pickup is 94565
Cheers
FinishBlack Ash
SeriesStudio L
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Question on the Fiio.
Do you know if it works with iPhone 6s? I'm wanting To use the DAC portion and reading conflicting reports about the Apple Camera Connection working to allow you to go iPhone - Camera Connection - USB in on the Fiio.
Some say you have to put a powered or unpowered USB hub in between the camera connection and the iPhone some say you don't. Some say if you turn off charging in the E17 it works others not so much lol....
So I'm confused.
I'm aware I could go iPhone - Lightning bolt to 30 pin connector - 30 pin LOD cable - Fiio but at that point the DAC is irrelevant and I could use any portable amp.
Thanks in advance for any input."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Question on the Fiio.
So I'm confused.
Not sure. I looked around and not much info out there. Only one I found is from Reddit. I was using a HTC phone.
CheersHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
Pm sent on sub.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Hey Dan, send me a camera connection cable and I'll check on my E17 & iPhone.
Jay
Hehehehe.... well I dont have a camera connection.... and spending 35 bucks to find out aint worth it lol....
I'm thinking either I just nut up and get the JDS Labs C5D + camera cable or just forget about needing a DAC and use the lightning bolt to 30 pin adapter to a LOD cable to get line level out of the iPhone and then just whatever headphone amp I want.....
... in order to add to the message of this post, I've enjoyed my E17 a lot. With my old iPhone I purchased cheap 30-pin to 1/4" stereo adapter (which doesn't bypass the phone's DAC) and was certainly able to enjoy tunes via my Senn HD555's.
Bump and good luck to the seller!Jay
No response to PM. Any update from OP?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
