"reference"
I see the word "reference" being used fairly often. Reference speakers, Reference system etc... IN GENERAL What does it mean?
ADCOM GTP-830 (pre-amp)
FREE THE WEST MEMPHIS THREE!
It basically means whatever gear someone feels is the best they have or have heard (reference point) vs something else.
Can also be the sound level at which you should calibrate your system. I think most consider reference level audio to be 75db, might be 80 I can't remember.Front
Polk RT800i (BI-wired)
Rear
Polk RT600i
Center
Polk CS400i (BI-wired)
Sub
SVS 25-31PCi (22Hz tuning port)... it's SubHuman
Receiver
YAMAHA RX-V1400
TV
Mitsubishi WT-46807 HDTV
HD receiver
T i V o HR10-250
