Weak link broke ?
boston1450
boston1450 Posts: 7,758
edited April 2015 in Electronics
So last week i finally got the MIT cables hooked up. Never listened to it till last night. Turned it on to warm up & put a dvd in & light sound coming from right speaker & no tweeters working. The week link in my Denon gear (pra1200) finally kicked the bucket. Started to listen to the movie playing with the front knobs11851jmrj801.jpg
& it just ate at me. Bingo' i have idea. On the Denon POA2200 there are knobs on back & they adjust power to speakers from amp. Low & behold when hooking the cables up to those big honking speaker connects on back i hit the power knob. Perfect. Something so simple i overlooked when back there made me think the weekest link in my set up was finally toasted was still good. So after 2 movies with the Mrs's she runs off to bed & i slap a Eagles sacd in & listen to it for a hour & i couldnt be more happier with where its at. The SDA's doing 2 channel on movies & music amaze me. The week link will have to wait as i have other projects ahead of that
No sub hooked to it. Dont need one. The little Pioneer is just sitting there waiting for buyer
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
  • gce
    gce Posts: 2,158
    Yeah, I've done something like that. My Amp's have a balanced/unbalanced button on the back and when I unplugged the RCA's to move things around I hit the button on one of them. Turned on some tunes and had no sound from one side...WTF!!!
    It's cool when you find out it's something simple... Good to hear you figured it out! B)
    Anaheim Hills CA,
  • boston1450
    Thats what happened. I thought i was screwed. Been undecided if i want to spend more money on this old gear. I might be better off with new at my age & knowledge
    Randy-Maine
    by David WMG
    So I take it you like the cables.....good, rock on.
  • boston1450
    I do & i do notice a difference too. Every little detail you do to these SDA's it seems to just get better n better. I got a friend that thinks im nuts for spending the dough. But every time i hear them is makes me nod my head YUP :smile:
    Randy-Maine
    by David WMG
    nooshinjohn Posts: 26,040
  • voltz
    voltz Posts: 5,384
    Rock on Brother * Rock on B) Glad your enjoy them!
  • boston1450
    Cables do make a difference :smile: rock on
    Randy-Maine
    by David WMG
  • boston1450
    John i should show this to the wife & tell her i need a new preamp. But im afraid she will do what this picture shows to me LOL too funny
    Randy-Maine
    by David WMG
  • boston1450
    Gonna try a pra1000 preamp mid week
    Randy-Maine
    by David WMG
  • boston1450
    Hope to listen to it this weekend. Matches beautiful with the wood sides on the amp
    Randy-Maine
    by David WMG
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited June 2015
    I thought the PRA-1200 was the replacement for the PRA-1000? When bought my SDA-1C's in 1989 I paired then with the PRA-1200 and POA-2400.
    The 2400 is identical to the 2200, except the level controls are on the front, and there are direct connections on the back that bypass them entirely.
  • boston1450
    Yes. You are correct. The 1200 i got has issues & i figured id try this route. I wanted the 1500 w/remote. But didnt want to go 200.+ It was only 127.00 to doorstep. If it doesnt pan out im going to go tube preamp. I really enjoy the poa2200. Ive used it cd player-to-amp & it is perfect. But i need the preamp because i run turntable & sacd player & tuner also. So a pre that has issues is a problem.
    Randy-Maine
    by David WMG
  • boston1450
    edited June 2015
    Super. Super. Super Sweet. Did i say Super. So much better. None of this in n out distorted sounds. Super happyqc5isyt17wx4.jpg
    Randy-Maine
    by David WMG
